Best Choice for Elevator Camera using CCTV
    A customer recently contacted CCTV Camera Pros and asked what the best choice is to install an elevator camera for 10 floors using CCTV. Here is the information that CCTV Camera Pros supplied.
    Here is the information that CCTV Camera Pros supplied:
    For transmission up to 1350 feet we highly recommend our ELT-L1350 wireless elevator CCTV camera which you can find here:
    http://www.cctvcamerapros.com/Elevator-Camera-CCTV-p/elt-l1350.htm
    This system provides a great solution for elevators as it does not rely on rf transmission which is always prone to interference and cross talk. There is no issue with any type of FCC/IC or any type of regulatory agency as light waves are not subject to any type of government approval. You can use these anywhere. You can have as many pairs as you want in the same location as there is no crosstalk or interference. They will work with NTSC as well as PAL cameras. They are good for at least 1350 feet minimum so they will address the majority of applications.
    Posted 7 months ago #
