CCTV Camera Pros recently had a customer contact us with the following question.
Question: BIPRO-S600VF12 looks great, but price 3x higher than I was expecting, compared to web searches. What makes it so great?
CCTV Camera Pros Response: What makes the BIPRO-S600VF12 is it versatility. The BIPRO-S600VF12 can be used in any application with an effective image. Please see key features below.
HIgh resolution 600 TVL Day (Color) & 700 TVL Night (Black and White)
.00004 Lux Rating - This allows the camera to stay in color mode even in limited light applications.
1/3” SONY High Sensitivity SUPER HAD CCD II - This High Sensitivity chip-set allow the camera to absorb more light, thus allowing for more vibrant colors and cleaner images.'
2.8-12mm Varifocal lens - This allows you to adjust the lens anywhere in between a 2.8-12mm lens (109 degrees to 22 degrees). The camera also has an adjustable infrared beam spread to adjust accordingly with lens angle/position. This comes in handy if you are trying to cover a wide area you can spread the infrared beam out or if you are looking at a distance you can have the infrared set to to a narrower angle to help penetrate at further distances.
HLC - High Light Compensation. Great for applications with heavy foreground light. Compresses light so it does effect the iris as it would with a standard CCTV Camera.
BLC - Back Light Compensation. This is used for applications with heavy background light. This helps eliminate shading and weird coloring you may run into due to background light.
DNR - Digital Noise Reduction. This helps eliminate video noise that may occur in night mode. Produces very clean image.
OSD - On Screen Display. The BIPRO-S600VF12 has a built in OSD This allows the installer to adjust settings within the internal software built into the camera. This allows the camera to be used in virtually any application.
Dual Voltage - Camera can accept 12vDC or 24vAC
Adjustable shutter speeds - This allows you to adjust the cameras shutter speed 1/60 - 1/120,000. Great for applications where you may be capturing faster moving objects such as wildlife , cars etc.
