A customer contacted us yesterday and asked the following question:
I currently have a Geovision surveillance system based in the GV-1480 DVR card. We are currently only using 10 of the camera ports and plan on adding 2 PTZ cameras to the system. In reading the Geovision PTZ setup instructions on your website, I know that we need to add a GV-NET card to our system in order to control the PTZ camera. I was wondering if we also need to buy a joystick to control the cameras.
CCTV Cameras Pros response to customer:
Please note that you do not need both the PTZ joystick and the GV-COM / GV-NET box. If you want to control the PTZ cameras with Geovision, you only need the GV-COM or GV-NET card. The Geovision GV-COM box or GV-NET card is required to send the RS-485 information to control the PTZ from the Geovision DVR to the PTZ camera. CCTV Camera Pros recommends the GV-COM over the GV-NET because it is easier to install being that it is USB and does not require an empty slot on your PC.
If you also want to use a joystick in conjunction with Geovision (instead of just controlling the PTZ cameras using your mouse and on screen controls) you would use a GV-Joystick from Geovision which can be found here:
http://www.cctvcamerapros.com/Geovision-PTZ-Joystick-p/gv-joystick.htm
The GV-NET setup instructions can be found here on our website:
http://www.cctvcamerapros.com/Geovision-PTZ-Setup-s/153.htm
The GV-COM setup instructions are almost the same ad can be found here:
http://www.cctvcamerapros.com/Geovision-GV-COM-PTZ-s/163.htm
Please let me know if you need anything else.
