cannot view camera locally
This topic contains 1 reply, has 0 voices, and was last updated by  Anonymous 4 years, 8 months ago.
  • #31478
    dvr set up using geovision 8.4. able to view cameras remotely but can not view cameras on a different computer in the back room.(same router as the dvr) how is this done? thanks
    #32382
    Ernie,
    While on site some networks will not allow you to use a remote address to connect while on site. So in this case you will need to connect via the local / private ip address. It usually will start with a 192. or 10.
    I hope this helps.
