The following chat transcript was taken recently while we helped a customer with Geovision webcam server problems.
Customer: I cant connect to the Geovision webcam server on my computer for some reason, but i noticed that all my other laptops that have windows xp installed work fine is there a reason? what do i have to do?
Geovision Support: Hello. Try disabling your firewall and make sure that Internet Explorer is set to enable or prompt for all active X settings.
Customer: I already did do that on all other computers, but this computer is set up with windows vista. i did the active x thing already.
Geovision Support: did you disable the firewall?
Geovision Support: are you running Geovision 8.12?
Customer: no i did not disable the firewall how?
Geovision Support: Go into the windows control panel and select classic view on the left, then select windows firewall
Customer: it is disabled, it says your computer is not protected.
Geovision Support: are you running version 8.12 of Geovision?
Customer: how do I know? I have a 16 camera system.
Geovision Support: one sec. let me see...
Customer: it lets me highlight mpeg4 encoder viewer then i click select, next page is the problem i cant select dsl it does not highlight and i cant select multiview.
Geovision Support: in your Geovision system click on the system button (the one with a hammer and screw driver), then select version information.
Customer: right know I am at a remote location but give me info and I will change the system right.
Geovision Support: if you are not on version 8.12, vista will not work and you need to upgrade. You can get instructions on upgrading here: http://www.cctvcamerapros.com/Geovision-Software-s/115.htm
Geovision Support: please let us know if you need anything else.
Customer: thank you
Geovision Support: Your Welcome.
