Connect Photoelectric Beam Sensor to CCTV DVR Alarm Input
Home > CCTV Security Camera & Video Surveillance System Forums > Stand Alone DVR Support > iDVR-PRO Series > Connect Photoelectric Beam Sensor to CCTV DVR Alarm Input
This topic contains 0 replies, has 1 voice, and was last updated by  Mike Haldas 1 year, 5 months ago.
  • #34150
    Key Master
    Can a photoelectric beam sensor be connected to the alarm input of a CCTV DVR? This is a question that I recently received at CCTV Camera Pros. Below is a transcript.
    Here are the questions from the customer.
    I read your article on how to connect external alarm devices to the alarm input of a a CCTV DVR. I found the support article very helpful.
    Please suggest me can I use photoelectric beam sensor and configure it with DVR which has ALARM-IN options on its back pane?
    I normally use these types of sensors on the walls of my customer’s retail and office locations. Whenever the beam is cut, the alarm is triggered.
    Can I place this on a wall and when beam is cut, the DVR will pop-up video on the screen of the camera that I associate with the alarm input?
    This is my response.
    Yes, a photoelectric beam sensor can be used to trigger the alarm input on an iDVR-PRO surveillance DVR.
    http://www.cctvcamerapros.com/CCTV-DVR-MAC-Viewer-s/403.htm
    You can use the same alarm input setup instructions that you originally referred to.
    http://www.cctvcamerapros.com/CCTV-DVR-Alarm-Input-Setup-s/860.htm
    On that page, I describe how to integrate a PIR motion sensor and a magnetic window sensor with the alarm inputs of the CCTV DVR. The setup is the same for a photoelectric beam sensor.
    photoelectric beam sensor trigger a cctv dvr alarm
    The DVR can be configured to take any of these actions based on an external sensor triggering an alarm.
    • Alarm Recording – the DVR will begin recording when an alarm is triggered.
    • Alarm Buzzer – the DVR sounds an audio beeping sounds.
    • Video Pop-up – the video channels(s) that are associated with the alarm appear on the screen.
    • OSD Pop-up – a message appears over the video that displays which alarm was triggered.
    • Email Alert – an email alert is sent.
    • FTP Upload – a snapshot of the event is FTP uploaded to a server.
    • PTZ Preset Location – if your system has a pan tilt zoom camera, you can program alarms to trigger PTZ cameras to go to a preset location.
    Early next year, we also plan on enabling the ability to receive a push notification on the iPhone and Android apps for iDVR-PRO.
    Please let me know if you have any additional questions.
