dvr h.264 and central management software 2.1.8.10
  1. gcannavi
    I currently own the dvr h.264, and it is not possible to access the dvr from a remote location using the cms software 2.18.10.
    What would you recommend that i do? I can access the dvr perfectly well within the local network
    Thanks
    Gustavo
    Posted 7 months ago #
  2. Mike
    Support Engineer
    Gustavo,
    If you are able to access on your local network but not remotely over the Internet, then most likely one of the following is the problem:
    • Your port forwarding is not setup correctly
    • Your modem has a firewall that needs to be disabled
    • You are using DSL with a separate router and your DSL modem is not properly bridged
    To setup your port forwarding, you must know what ports your DVR uses and you can refer to these instructions:
    http://www.cctvcamerapros.com/Internet-Surveillance-Setup-s/156.htm#port-forwarding-setup
    If you are using DSL and you need to find out if there is a firewall or if your DSL modem needs to be bridges to your router, you should contact your service provider.
    Posted 6 months ago #
