A DVR user recently contacted CCTV Camera Pros with the following issue:
I have read a lot of good articles on this site to help me set up my stand-alone triplex 8ch dvr for remote viewing, but still have one minor issue that I can't seem to get any help on. I have the dvr and a linksys router with time warner cable modem. The router is configured to auto IP (needs to be for cable) so I have a dyndns host. I use the port forwarding in the router to forward ports to my dvr and enabled ddns. The dvr is assigned a static IP outside of the dhcp range in the router for my home network. Everything seems to work fine, I can connect internally and externally...except after I connect externally the dvr has to be power
cycled to reboot before the remote view works again. This is really confusing to me, and any suggestions you have to help me are appreciated!
CCTV Camera Pros Response:
Thank You for contacting CCTV Camera Pros. That is a strange issue that you described but we do have a suggestion and some insight.
[list=1]
I hope this info is helpful. Please let us know if you need anything else.
