Geovision computer locking up
This topic contains 4 replies, has 0 voices, and was last updated by  jomma5 6 years, 1 month ago.
Viewing 5 posts - 1 through 5 (of 5 total)
  • #31248
    jomma5
    I got everything working on our GV800 system. Problem is….about once a week, the CPU stays on (lights/fans) but the monitor turns off completely. I have swapped monitors, cords, unplugged/plugged back in, etc and same thing regardless. I have even switched graphic cards.
    I am thinking its either the CPU, motherboard, or the GV800 card doing this. Has anyone ever heard of this before or does that trigger any thoughts of what could be going on?
    Its working fine now and has for about 5 days. Its usually around the 6-8 day range when this happens. I have to unplug the CPU then turn it back on…then everything works fine. When the system does this goofy thing, you cannot connect remotely to watch the cameras nor does it record.
    computer specs:
    MSI 870-G45 AM3 AMD 770 ATX AMD Motherboard
    AMD Phenom II X2 555 Black Edition Callisto 3.2GHz
    G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 …
    HITACHI Deskstar 7K1000.C HDS721010CLA332 …
    ASUS DRW-24B1ST/BLK/B/AS Black …
    Antec One Hundred Black ATX Mid Tower Computer ….
    COOLER MASTER eXtreme Power Plus RS-500-PCAR-A3-US 500W
    PowerColor AX3450 512MD2-H Radeon HD 3450
    GV800 card pci-e x1 8.4 software
    #32216
    jomma5
    windows 7 professional 64bit forgot to add that
    #32217
    Jomma5,
    Is it possible that the PC is going into a sleep mode?
    #32218
    jomma5
    yea thats the first thing i thought of as well…but nope ive verified that it is not
    #32219
    I do not see that motherboard / PC build on the list of ones that Geovision recommends. You can confirm here:
    http://videos.cctvcamerapros.com/pdf/geovision/Geovision-Recommended-Motherboards-Suggested-PC-List.pdf
