A potential customer recently contacted CCTV Camera Pros with some questions related to Geovision and then NUUO. Here is the transcript:
Customer:
I am interesting by your PCPRO-GV8 Geovision DVR Computer but I need some information on it. I plan to put 4 analog camera and 4 megapixel IP camera (with H264) on it Every camera would be run on Geovision DVR surveillance software. Is it possible? How much IP camera can I connect to Geovision DVR software ?
Support:
You would need to purchase the Geovision IP license found here in addition to the PC that you mentioned:
http://www.cctvcamerapros.com/Geovision-NVR-Software-p/gv-nvr.htm.
And then you would be able to do everything that you mentioned.
Customer:
If I bought GV-NVR Geovision IP Security Camera Software, NVR License, 3rd Party Cameras with 4 camera licenses, do I need to run two software separately to run my camera : one for ip camera ( Ip security camera software) and one for analog (geovision) or can I integrate both camera (ip and analog) in geovision version 8.2 with the IP licenses.
Support:
Yes, you can integrate the Geovision DVR cards, Geovision 1st party IP camera licenses, as well as Geovision 3rd Party IP camera licenses on the same Geovision PC.
Customer:
Do you know if geovision NVR software 3rd party IP camera version is compatible with:
- AV5155DN 5.0 megapixel MegaDome Armor Dome H.264 IP Camera from Arecont Vision SKU#: AV5155DN
- ACTi ACM1232 Megapixel uotdoor IP IR bullet camera.
Support:
I am sorry but those cameras are not yet supported yet according to the latest Geovision IP camera compatibility list.
Customer:
If I use the Nuuo NVR mini network video recorder 4 channel, $899.99 and connect it to the same network of my geovision computer, do you think it is possible to do that? Do you know if my 2 ip camera megapixel are supported by Nuuo NVR?
Both models are not listed on your list of compatible IP camera.
Support:
Here is a link to the list of supported cameras by the NUUO NVRmini:
http://support.nuuo.com/mediawiki/index.php/NVRmini_supported_cameras
Connecting a NUUO NVR it to the same network as a Geovision system is not a problem.
Please let me know if you have any other questions.
