Geovision fisheye cameras
This topic contains 2 replies, has 0 voices, and was last updated by  Anonymous 3 years, 12 months ago.
  • #31563
    With the fisheye cameras can you have multiple camera views that stream on different mjpeg streams?
    Using remote automation apps like RTI or HAI HAIKU or SNAPLINK they require a mjpeg URL stream for each camera.
    Considering viewing the standard fisheye view would be useless I would like to predetermine views inside the geovision software and output those views as different streams. Hence having multiple cameras off the one fisheye camera without the need to swap apps unless extra features or history viewing is needed.
    #32453
    Hi Tim,
    Unfortunately, Geovision 360 fisheye cameras do not stream a dewarped MJPEG stream via URL. At this time, only our the Geovision PC-based surveillance applications can dewarp the Fisheye view.
    Geovision does intend to enable this in the GV Mobile Server. However, it is not yet available.
    -Mike Haldas
    #32454
    Thank you for the reply Mike.
    Is there a way for the software to dewarp the image from the camera and have pre-set views that you want to be re-streamed from the software back out onto the network as a mjpeg stream?
    The reason I ask is that to put these cameras around a house the customer would like to be able to view the camera remotely on an iphone or other application. One view to be at the rear door, another one off the same camera of the pool. Otherwise these cameras have a massive limitation in the domestic market in this regard at the moment.
