Geovision Intel Atom Processor Support
    A customer recently contacted CCTV Camera Pros with the following question:
    Would you happen to know if the GeoVision GV-800 Video Cards would work in a system running and Intel Atom 330Dual Core 533MHz CPU with 2G Ram?
    CCTV Camera Pros support response:
    CCTV Camera Pros does not build any Geovision systems with Atom processor so we are not 100% sure, so we will open up a case with Geovision to check to be sure. I know that typically the Intel Atom processors are used in very small laptops and PCs, so I would recommend that you first make sure that the PC you are looking to install the Geovision DVR card in has enough clearance and room for the PCI or PCIe Geovision DVR card.
    Please let us know if we can help further. When we hear back from Geovsion support, we will post their response here also.
    Posted 2 years ago #
