geovision software upgrade procedure
  1. mcsworks
    Hi,
    I own a PC with geovision 8.3 software installed on it by cctv camera pro. I download geovision 8.3.1 new version. How do I make the upgrade ?
    Do I need to uninstall the older version and make a new install or can I overwrite on the old version ?
    Thank you for your help!
    LOU
    Posted 2 years ago #
    Lou,
    This is the process that we follow to upgrade Geovision software:
    1. Uninstall the Geovision software using the uninstall program (this should be located in your Windows start menu in the Geovision section
    2. Run the new Geovision installation program from your DVD or download file
    3. Choose install driver first and select remove first to remove the old Geovision drivers
    4. Choose install driver again to install the new Geovision drivers
    5. Install the new Geovision main program last
    Please let us know if you have any further questions.
