Geovision Surveillance System Remote Viewing Bandwith Calculator
    A customer contacted CCTV Camera Pros and asked the following questions related to a Geovision surveillance system:
    Does Geovision have a bandwidth calculator for customers to calculate / estimate upload requirements / bandwidth speed for Internet connections based on streaming 16 cameras. Also if there is a way to limit remote viewing to only certain cameras to conserve bandwidth.
    Geovision technical support responded with the following information:
    Yes there is a Geovision bandwidth calculator available online here: http://www.geovision.com.tw/english/cal_webcam_test1-5.asp
    For 16 channels of CCTV cameras over the internet, it usually required around 1Mbps to 2Mbps of upload speed depending on resolution settings of the cameras.
    You can manipulate the quality and number of cameras that can be seen across the web using the Geovision main console.
