GV-VS02 Geovision IP Video Server
(5 posts)
  1. antona
    I am using GV-VS02 Geovision IP Video Server and wanted to know if there is a way to use iPhone and Android phones for viewing live feeds on my phone. Any help would be much appreciated.
    Many thanks.
    Posted 5 months ago #
  2. JCHaldas
    Moderator
    Antona,
    The GV-VS02 will not allow you to log in via Iphone or Android. You would need a GeoVision DVR card with 8.32 software or later which you can find here http://www.cctvcamerapros.com/Geovision-DVR-Cards-s/27.htm
    with this you would be able to view via iphone, blackberry and other supported phones which can be found here http://usavisionsys.com/files/Mobile.pdf Im not sure if android is supported.
    Hope this helps
    James
  3. antona
    many thanks. i knew dvr card is supported by unfortunately my pc is a book pc rather than a full blown computer (i.e. no normal expansion card slot) and i prefer not to have my pc turned on all year round. so i guess there is no solutions then.
    thx anyways!
  4. JCHaldas
    Moderator
    Antona,
    Using an application similar to what you are using now it is possible to view from an iphone. You would need a video server that is compatible with iphone like this Zavio video server http://www.cctvcamerapros.com/Zavio-Network-Video-Server-p/v111t.htm Unfortunately they do not make a two port server so you would have to purchase one for each camera. Once you have the servers setup you can view from your iphone going right through the safari web browser http://www.cctvcamerapros.com/iPhone-Setup-for-Zavio-IP-Cameras-s/349.htm Or you can use the free iphone app provided by CCTV Camera Pros which is compatible with the Zavio & Vivotek Servers and Cameras. http://www.cctvcamerapros.com/CCTV-Camera-iPhone-App-s/362.htm
  5. Mike
    Support Engineer
    antona,
    Another option is to use the Geovision IP software (NVR software) as seen here:
    http://www.cctvcamerapros.com/Geovision-NVR-Software-p/gv-nvr.htm
    The Geovision IP camera software also includes the Geovision 8.32 software that James was referring to that supports iPhone viewing with the GV-iView iPhone app.
    I hope this helps.
please bookmark or share this page for future reference
