H.264 DVR WITH 2WIRE 2701HG-B
This topic contains 5 replies, has 0 voices, and was last updated by  Anonymous 4 years, 3 months ago.
Viewing 6 posts - 1 through 6 (of 6 total)
  • #31553
    I'm having trouble to view my H.264 with my iphone from outside of my home. When i'm inside home with iphone with wifi on, it works, but without wifi it wont work. Think something have to do with port fowardiring or firewall. Need some help how to make it work.
    Many thanks
    #32438
    Hello FireAir,
    It definitely sounds like you will need to forward the port / ports for your DVR.
    Here is a link to our iDVR-E Network / Port forwarding setup. CLICK HERE FOR INSTRUCTIONS NOTE: The menus on our DVR are going to look different, however the concept should be the same.
    Please let me know if you have any further questions.
    #32439
    Hello JCHaldas!,
    Thank you very much for the link…. found out that the port was closed. I will need to contact my provider to bridge the modem. I keep you posted.
    Many thanks
    #32440
    Still no luck trying to make it work. I looked up the link you send it to me, it was somewhat different than what I have. I'm little confused on which select I should pick on "Choose the computer that will host applications through the firewall" I have 18 on it. Is there any other link that I can look at it to make it work ? Also how can I find the right port # ? Many thanks
    #32441
    Hello there,
    Can anybody help me to get mine H.264DVR to get it work ?
    Thank you
    #32442
    FireAir,
    Please take a look at this article. The concepts are the same for all network DVRs and IP cameras, but for the specific instructions for your DVR and router, you need to consult with those manuals for the specifics.
    http://videos.cctvcamerapros.com/icamviewer-cctv-iphone-app/ip-camera-3g-wifi-access.html
