HD CCTV Camera with YPbPr Component Video Out
Home > CCTV Security Camera & Video Surveillance System Forums > HD CCTV HD-SDI Surveillance > HD CCTV Camera with YPbPr Component Video Out
This topic contains 0 replies, has 0 voices, and was last updated by  Mike Haldas 4 years, 8 months ago.
  • #31527
    A customer contacted CCTV Camera Pros recently with the following question related to an HD CCTV camera.
    Do you carry an box style HD-SDI CCTV camera in color with a YPbPr component output?
    Application requires widest angle at 12ft and is indoors where dim lighting goes down lower to few lux.
    Also able to handle the bright light coming through window, would be a plus.
    The following Geovision GV-SDI-BX110-0 HD CCTV camera has BNC video output and the 2.8mm setting of the lens varifocal lens that is included would give you an very wide field of view:
    http://www.cctvcamerapros.com/HD-SDI-CCTV-Camera-p/gv-sdi-bx110-0.htm
    This camera is also very capable of low light video capture, however, if you require zero light I do recommend an infrared camera.
    The BNC output of the camera can be converted to an HDMI out using one of these devices but unfortunately CCTV Camera Pros does not carry a BNC to YPbPr component.
    http://www.cctvcamerapros.com/HD-SDI-to-HDMI-Converter-p/sdi-cr1.htm
    You should be able to use an HDMI to YPbPr component converter to use with the above equipment, but we have never tested that.
