Hidden Nanny Cam with iPhone 3G Viewing
  1. CCTV Jimmy
    Moderator
    A customer recently contacted us with the following:
    I'm looking for a nanny cam or hidden cam to place in my house, however i wish it to be able to stream to my iPhone 3G S. I want something that's inconspicuous and that will work for what I want it to. Any suggestions would be greatly appreciated.
    CCTV Camera Pros Response:
    Thank You for contacting CCTV Camera Pros. The simplest way to do this is my using an IP camera like this one:
    http://www.cctvcamerapros.com/Wireless-IP-Camera-p/zavio-f312a.htm
    It is not the most inconspicuous camera as you see it there, but be aware that the stand is optional and you can put that camera anywhere. The only part of the camera that needs to be exposed to record video is the lens that you see on the front of the camera which is about the diameter of a nickel. Another nice feature of this camera is that it has built in wireless, so it can be configured to connect to an existing wireless home router. This camera is also iPhone compatible.
    Another option is to use a hidden spy camera such as this alarm motion sensor camera:
    http//www.cctvcamerapros.com/Motion-Detector-Security-Camera-p/pir-520c.htm
    However this camera is hard wired and must be connected to a network video server to make the video stream accessible from your iphone:
    http://www.cctvcamerapros.com/Video-Encoder-p/vivotek-vs7100.htm
