Horizon Tilt Up Setting on PTZ Camera Not High Enough
Home > CCTV Security Camera & Video Surveillance System Forums > PTZ Camera Support > Horizon Tilt Up Setting on PTZ Camera Not High Enough
This topic contains 0 replies, has 0 voices, and was last updated by  Mike Haldas 6 years ago.
  • #31244
    A customer recently contacted CCTV Camera Pros with the following question related to the PTZ-9480X10 pan tilt zoom camera:
    Can you please let me know if the PTZ-9480X10 has a horizon adjustment? I am not sure if you have heard of this but our some Pelco and Bosch PTZ cameras have an adjustment that you can make on the camera so that when the camera is tilted all the way up, it can go a bit higher. We are having trouble getting a high enough angle on objects 100 feet away from where our PTZ is mounted. Can you please let me know if this camera has some type of adjustment like this?
    Yes, adjusting the tilt setting / horizon setting higher is possible with the PTZ-9480X10 camera. Here are the instructions:
    To release the default horizon setting (tilt up) to tilt higher, use a PTZ controller and enter the following on the keyboard:
    Call + 70 + Enter
    If you want to adjust the horizon height of the PTZ back to original factory default setting enter:
    Preset + 70 + Enter
