I have a 16 camera system But I am only using 8 cameras. On my screen it showas 8 pictures and 8 blank chanels. How can i delete the blank channel and only see 8 actual cameras.
Hello Renny,
It depends on the DVR. Some DVRs may not have this feature. But typically it is available. You should be able to change the grid format to only display the 8 cameras. Or available with some DVRs there is a setting to enable or disable certain channels.
I hope this helps
Posted 1 year ago # -
How do I change the grid format? where do i find that?
Renny,
It depends on the DVR. Do you have the model # of the DVR?
Oh,yes,I think so.
Posted 9 months ago # -
It all depends on your DVR. If it can support such kind of functions, then you can find it in the menu. It is a good idea to try to enable or disable certain channels.
Posted 3 months ago # -
The key lies in the DVR.
Posted 1 week ago #
