How to connect GV-DSP Server to the GV-LPR System
Home > CCTV Security Camera & Video Surveillance System Forums > Geovision Surveillance Support > How to connect GV-DSP Server to the GV-LPR System
  • #31422
    1. Log onto the web interface of the DSP LPR.
    2. Go to Events and Alerts > LPR Remote Server
    3. Input the IP address of the GV-LPR system into the field indicated below and click Apply:
    4. Go to the GV-LPR system and do the following:
    a. Click on the Network button and select GV-DSP LPR Server to activate the service.
    b. Go into the System Configure window, click the camera tab that you would like to assign the DSP LPR to, click the General tab, select GV-DSP LPR Server, and select the DSP LPR from the drop down.
    c. Once finished, you should see the video from the DSP on the main screen.
