How To Reset GeoVision Multicam Password?
  1. JCHaldas
    Please see link for GeoVision password reset instructions: http://videos.cctvcamerapros.com/downloads/geovision/Password_Removal_Procedure_.pdf
    If you were not able to reset GeoVision Password via instruction above please proceed with below instructions.
    CAUTION: This procedure can be very dangerous and can cause issues if not done correctly. CCTV Camera Pros is not responsible for issues or damage caused. PROCEED AT YOUR OWN RISK!
    1.) On your windows desktop click the "Start" button. In the search field type in "regedit" and press the "Enter" key.
    2.) Double-click the "HKEY_LOCAL_MACHINE" folder to expand it on the left-pane of the Registry Editor window that opens.
    3.) Double-click the "HKEY_LOCAL_MACHINE" folder to expand it. Double-click "Microsoft" folder and click the "DataCode" folder.
    4.) Highlight all the default values in blue and delete them by right clicking on the mouse.
    5.) Close Registry Editor and reboot the computer.
    6.) Now type in the new Login information. Also you may want to check the "Allow Removing Password System" option so you do not have to mess with the PC registry as this can cause major issues if not done correctly.
    7.) Press the "OK button to Login.
    Now your password should be successfully reset.
    Posted 7 months ago #
