Security Camera & Surveillance System Support Forum » iDVR Stand Alone DVR Support » iDVR-E Series
How to Setup Email Alerts on iDVR-E Recorders
  1. JCHaldas
    In this post I will show you how to setup the email alerts for the iDVR-E Video Surveillance DVR.
    In order for the email alerts to work properly you will need to make sure the DDNS server is setup within your iDVR-e.
    1.) Make sure you have the motion setup per camera you would like to receive email alerts for. (Please refer to pg. 33-34 of the iDVR-E manual for more info)
    2.) Turn on the Email alerts. To do this you will need to go into the network menu on the DVR. Now go into the Email setup tab. You will now set it to default. Now below you will see Email Address, this is where you will input the email address you would like the alerts to be sent. You can enable up to 5 different email address. (pg. 45 of the manual)
    3.) If you would like email to be sent only at certain times of the day then you will need to setup schedule recording. (pg. 40-41 manual)
    Posted 11 months ago #
