How to use CAT5 cable to wire analog CCTV cameras to DVR
This topic contains 0 replies, has 0 voices, and was last updated by  Mike Haldas 4 years, 6 months ago.
  • #31504
    A customer recently contacted CCTV Camera Pros with the following questions related to useing CAT5 cable with analog CCTV cameras.
    I could use some guidance and supplies to get a three camera surveillance system setup at my house. I have an analog CCTV DVR and the contractor ran Cat5E 24 AWG wire from each camera to the DVR in the mechanical room. So what i need to know is what i can do to get it hooked up on the DVR end (cameras are already hooked up). The Video In for the Cameras are Male BNC, not a hundread percent sure if power is to the cameras already or not, but I would assum that they might need to receive power down the Cat5E wire as well. I will also need an end for Internet for the Cat5 they ran for network connection.
    Thank You for contacting CCTV Camera Pros. You can use CAT5 cable to run analog video for CCTV cameras using these video baluns:
    http://www.cctvcamerapros.com/CCTV-Balun-p/vb-2vs.htm
    If you want to also run the power over 2 of the twisted pairs in the CAT5 cable, you can use these video and power baluns:
    http://www.cctvcamerapros.com/UTP-CAT5-Balun-p/balun-pv5fm.htm
    Please let us know if you have additional questions about this or anything else.
