We recently had a customer call in with the following question:
Q: We purchased a NUUO 32 cam server and are having problems displaying all 32 cams on the monitor simultaneously.
A: In the NUUO Main Console I want you to click the configure button and then go into system settings. Once you are in the system settings click the monitor display tab. Now under layout you will see NXN type. Next need to select 6 x 6. Once you have done that press the ok button to save the settings and go back to the live view. Last click the N button next to all the different screen divisions.
A2: If you are still having issues click the Configuration button and go back into the System Settings menu. Now go to the Camera Tab. Last uncheck all of the active cameras and then recheck the cameras. Now you should be able to view all of the cameras on the same screen.
