A customer recently contacted us with the following question:
Can I use regular outdoor camera housing for a night vision ( infrared ) camera, or will I get a reflection in the front glass of it?
Thank You for contacting CCTV Camera Pros. Most outdoor infrared cameras are already inside of weatherproof housings so adding one is not necessary. If you need to put a box style camera, which can not go outdoor without a housing, you can use an infrared outdoor camera housing like this one:
http://www.cctvcamerapros.com/Arecont-Infrared-Housing-p/hsg1-o-w-ir.htm
Please note that for a camera to work correctly with an infrared housing, the camera must support and night mode where the camera turns to black and white. This is a day night camera that would work with an outdoor IR housing:
http://www.cctvcamerapros.com/High-Resolution-Security-Camera-p/pro-630dn28.htm
Please let us know if you need anything else.
