iPhone app – can't add second camera?
Home > CCTV Security Camera & Video Surveillance System Forums > iPhone IP Camera & iPhone CCTV > iPhone app – can't add second camera?
Viewing 4 posts - 1 through 4 (of 4 total)
  • #31232
    Inactive
    re.: iPhone app – can't add second camera?
    Hi, I am using the iPhone iCamViewer app successfully to view a IP camera, but I'm having difficulty adding a second camera.
    When I click on the + button at the top-right corner of the screen (in the My Cams" view), the app goes to the same exact screen as the Config button. Thus, the + button is not allowing me to add a second camera, but instead is overwriting the settings of the first camera with the settings of the second camera.
    What am I doing wrong?
    Thanks!
    #32195
    Inactive
    Well, I think that I have figured out my problem! In the camera setup, I had not named my first camera.
    Apparently if you do not give the camera a name, the app will not allow you to add a second camera, but instead returns you to the configuration screen.
    With best regards,
    #32196
    patrickhenry,
    Thank You for posting and letting us know that you found the issue. This has been noted and next time we publish an update to the iCamViewer app, we will make it so that the camera name is a required field to avoid confusion.
    #32197
    Inactive
    When I upgraded to iOS 4, I had pictures in 3 places. These seemed to correspond to places I had used my iPhone 3GS camera (Placed didn't show a map, just the checkerboard pattern). When I went to take a picture with the iPhone camera, I was prompted for permission to use my location—I gave it. Now I have only a pair of pictures taken at my home, the other locations are gone. I don't have the latest version of iPhoto. Has anyone else seen this?
