Security Camera & Surveillance System Support Forum » IP Camera Support
iphone Security Camera Support Questions
  1. Mike
    Support Engineer
    A customer emailed us with the following questions related to the iPhone surveillance & security camera systems that we are promoting:
    1. This can be wired directly to a router? Or a number of them to a router.
      Answer: Yes, the IP cameras are wired directly to a router or network switch and yes you can connect multiple IP cameras to a router or switch
    2. Also will the wireless IP camera work with this that comes up on the same page.
      Yes, this wireless camera has been tested are works great: http://www.cctvcamerapros.com/Wireless-IP-Camera-p/zavio-f312a.htm
    3. I assume this will also work with IP camera system.
      It depends on which system. Some of the systems do not directly support remote login with the iphone, but you can still access the camera directly (outside of the recorder) to see a live image from the iphone.
    4. Is there anyway to use a mac computer with this software as the recording media and have the cameras go hardwired into a router or wireless router.
      Unfortunately, you can not use a MAC with the recording software, but you can view the cameras from a MAC in the safari web browser
    Please post any follow up questions related to iphone surveillance camera viewing to this forum topic.
    Posted 12 months ago #
  2. Mike
    Support Engineer
    Follow up iPhone questions from customer:
    1. Which out door IP cameras wired and wireless will work. I phone/mac. I guess you could put in a housing.
      All of the IP cameras on this page have been confirmed to work with the iPhone & MAC using safari: http://www.cctvcamerapros.com/iPhone-Surveillance-Camera-Systems-s/347.htm
      These network video servers can allow any CCTV camera that we supply work with iPhone & MAC:
      http://www.cctvcamerapros.com/Zavio-Network-Video-Server-p/v111t.htm
      http://www.cctvcamerapros.com/Video-Encoder-p/vivotek-vs7100.htm
    2. I would guess the software could be run on a MAC that was using Parrells running Windows. Will the software allow recording.
      You can not use your MAC for recording. For recording, a windows PC is required or a stand alone network video recorder (NVR).
    3. Can the software allow viewing and recording for multiple locations.
      Viewing from multiple locations is not a problem. Recording is more tricky because if requires a lot of upload bandwidth speed to do.
    Please post any follow up questions.
