location of a outdoor camera
(3 posts)
  1. pingadude
    I own a color low lux wide angle (3.6mm) outdoor security camera. My dilema is where to locate the camera to get the best view. I know where to put the camera and what wall but im confuse at what height. The camera is covering a small 4 car parking lot and garage. Where im thinking to put the camera there is a Sodium light in the middle of the wall (1) Do I put the camera above or below the light or doesn't matter
    (2)I need to cover as much of the lot as possible...blow the camera there is entrance door
    Thanks
    Posted 2 years ago #
    pingadude,
    Thank you for posting to CCTV Camera Pros forum. In answer to your questions:
    1) I would recommend putting the camera below the light if possible.
    2) A good height to mount cameras with a wide lens, 3.6mm for example, is at about 10 - 12 feet from the ground. This gives you a good viewing angle and generally is out of reach from vandals.
  3. maxv
    In addition to Mike's advices above I would also suggest to check your actual field of view in 3D using 3D modeling software.
    There is a special planning software to calculate CCTV camera coverage
    For example in your case you can add/draw a picture and add test objects (cars in your case).
    IP Video System Design Tool calculates actual field of view, angles, dead zone size and result resolution in pixels/foot or pixels/meter. The last version supports import of floor plans or site plan image from BMP/JPEG.
    Here is a sample picture:
    You can use the software in the demo-mode for 45 days.
