Pelco IP Camera Test Monitor
This topic contains 0 replies, has 1 voice, and was last updated by  Mike Haldas 2 years, 1 month ago.
  • #33846
    Key Master
    Does the MON-IP7 test monitor work with Pelco IP cameras?
    I received the above question this morning from a customer that wants to use the MON-IP7 video tester with Pelco IP cameras. Here is the information that I provided.
    The MON-IP7 test monitor for IP cameras will work with any IP camera that is compliant with ONVIF standards. Pelco is a full member of ONVIF, so most or all of the IP cameras that they manufacture should be developed using the ONVIF standards. The exception to this is older models that were manufactured by Pelco before ONVIF was in place.
    We have a 20 day return policy. You can order the tester and try it out with one of your cameras. If it does not work, you can return it for a refund as long as it is returned in new condition will all accessories and packaging materials.
    Here is a link back to the product page in case you decide to order.
    http://www.cctvcamerapros.com/IP-Camera-Test-Monitor-p/mon-ip7.htm
