Recommended PTZ camera for continuous motion
  1. ChenD
    Hi experts,
    I would like to get your opinion and recommendation about a good PTZ camera.
    1st major requirement is to be able to move smoothly and continuously between several pre recorded presets. i.e. I would like to capture 3 points, then let the camera move from P1, to P2, to P3 with a defined speed and acceleration.
    2nd most important requirement is to adjust to speed and location/zoom changes: for example, to be able to control the camera (by code, not interactively), to move to points "near" the recorded points (e.g. 1 deg left from P1 with speed that is x1.2 faster than the recorded speed).
    All is done via code, except first points capturing.
    I found out that Axis Communication and Sony cameras cannot do it - both force delays and stop when reaching P1, P2, P3.
    Any idea if there are other brands that may support mentioned requirements?
    Thanks,
    Dan
    Posted 5 months ago #
  2. carlos
    Moderator
    I would look into this camera, it supports most all the functions you are looking for and the tech support behind it can help you program in those functions.
    Geovision PTZ
    Posted 4 months ago #
