Replacement PTZ camera parts for repair
Home > CCTV Security Camera & Video Surveillance System Forums > PTZ Camera Support > Replacement PTZ camera parts for repair
This topic contains 0 replies, has 0 voices, and was last updated by  Mike Haldas 4 years, 9 months ago.
  • #31483
    A customer contacted CCTV Camera Pros with the following questions recently:
    I have a camera from our system that no longer works. It is an outdoor analog PTZ camera apparently made by a company called ISC and is approximately four years old. I have a few questions about it for you.
    – Is it worth repairing?
    – What can we replace it with?
    – Is it possible to get a digital camera and feed the analog DVR with it?
    Sorry to hear that you are having trouble. Please see answers to your questions below:
    – Is it worth repairing? Typically no. In most cases replacements parts for legacy PTZ are not available and if they are, they cost as much as a replacement.
    – What can we replace it with? I recommend that you take a look at these two options:
    http://www.cctvcamerapros.com/IR-PTZ-Camera-p/ptz-wir12x.htm
    http://www.cctvcamerapros.com/Pan-Tilt-Zoom-Camera-p/ptz-a10x.htm
    Yes, but you need to use a decoder to change the signal from digital to analog. So for example, you can use this camera:
    http://www.cctvcamerapros.com/Outdoor-IP-PTZ-Camera-p/ip-v97151.htm
    and decode the signal using this device:
    http://www.cctvcamerapros.com/Video-Decoder-p/vivotek-rx7101.htm
