Software is Incompattible With Your Location
This topic contains 2 replies, has 0 voices, and was last updated by  JCHaldas 6 years, 4 months ago.
  • #31133
    We recently had a customer call with the following issue:
    I have set up a new server running Windows XP and I am getting an error message saying that the software is incompatible with your location every time that I reboot the system. It happens before the software loads and will not load until you select okay. Do you have any idea what could be the cause of this?
    Solution: Disable the IR Remote control on startup
    #32083
    sibannac
    What if you get this error and the IR Remote Control is disabled?
    #32084
    Sibannac,
    You may want to try uninstalling the software and reinstalling. Also if that does not work please try upgrading to the newest version of software which is 8.4.
