Vivotek VS7100 Video Server iCamViewer iPhone App Setup
(3 posts)
    A customer emailed us with the following question related to our iCamViewer surveillance camera iphone app:
    I got the VS7100 along with the Icamviewer app on my iphone. I can't seem to get this to work - is there additional setup instruction available?
    Here is the answer:
    In order for the Vivotek VS7100 network video server to work with the iCamViewer app, you must set the 1st video stream to MJPEG, by doing the following.
    1. From a web browser login to you VS7100
    2. Click on the Configuration link on the left side of the screen
    3. Then click on the audio & video link on the left
    4. On the Audio & video settings screen set the mode to JPEG for the first stream as seen below:
    Note: you can still use set the 2nd stream to MPEG if you want to record MPEG video on your NVR.
  2. jmh64
    This helped so now I am able to stream to the app in my homenetwork using port 554.
    But how to setup port forwarding in my router to access from "outside" I have port 554 forwarded which have worked before using mobile phones but seems not enough for the iPhone app.
    And what about "Authentication" in the VS7100 setup?
    Posted 1 month ago #
  3. jmh64
    I told that this setup above helped but that whas not the case.
    It seems that connecting to port 80 and 554 works and gives motion video for about 5 seconds and the disconnects.
