What terminal block posts do I hook up the rs485 and sensor?
Home > CCTV Security Camera & Video Surveillance System Forums > PTZ Camera Support > What terminal block posts do I hook up the rs485 and sensor?
This topic contains 1 reply, has 0 voices, and was last updated by  Anonymous 6 years, 2 months ago.
  • #31245
    I ran a cat five to the (PTZ-WIR12X) IR PTZ Camera. There is a single black wire that comes out of the camera with the wiring harness which I am clueless of what to do with as well as the installation instructions not being clear on where to hook the rs-485 two conductor and also the sensor wires. I would appreciate where I could find a manual or get the terminal block diagram. the small block from left to right:
    NO NC CM G AX the CM and the G are white and the rest are yellow. The larger terminal from the left to right: . . G s1 s2 s3 s4< I assume that this terminal block may be for sensors. Any help will be appreciated.
    #32214
    Hello ScottFuel,
    Here is what the terminals on the PTZ are for.
    NO: Normally Open
    NC: Normally Closed
    CM: Common
    G: Ground
    And for the G S1 S2 S3 S4 seem to be for sensor inputs.
    G: Ground (used for all Sensor ports)
    S1: Input Sensor 1
    S2: Input Sensor 2
    S3: Input Sensor 3
    S4: Input Sensor 4
    I hope this helps
