Security Camera & Surveillance System Support Forum » IP Camera Support » Zavio IP Camera Support
Zavio F210A disconnected
(5 posts)
  1. Tracy5186
    Having a problem with the F210A... Connected it to the router's port, and it worked great - could see video and change settings. Then tried to bridge the router to the modem (so as to only have to forward ports on one piece of equipment, not both). Now when I use Bonjour to access IP cam, the screen loads but it says "-3285: disconnected" at bottom of screen where video should be playing. Can't access settings either. Have reset it several times, and restarted router/modem/computer, too. Any ideas why that would happen, or how to fix it?
    Thanks!
  2. JCHaldas
    Hello Tracy5186,
    Are you using Leopard or Snow Leopard OS?
  3. Tracy5186
    I'm guessing Leopard - about this mac states version 10.5.8.
  4. Tracy5186
    If anyone is interested, the solution was to download the newest firmware from Zavio's website, and upload it to the camera. I can now access the camera repeatedly without it permanently disconnecting and needing a reboot.
  5. Mike Haldas
    Tracy5186,
    Thank You for sharing the solution to this problem!
