Security Camera & Surveillance System Support Forum » IP Camera Support
Zavio IP Camera Installation on Mac
(10 posts)
  1. Mike
    Support Engineer
    The installation software included on the CD, including the intelligent IP installer, that comes with Zavio IP cameras is for Windows only, but Zavio IP cameras work with Mac computers using the Safari web browser. So, many of CCTV Camera Pros Mac customers run into trouble when trying to install a new Zavio camera and they only have MACs and no PCs available to work from.
    CCTV Camera Pros has tested and documented the following setup process for Zavio cameras when using a MAC computer.
    1. Instead of using the IP installer that ships with the Zavio cameras, download and install the following IP installer program on your MAC: IP scanner for MAC. The program needs to be downloaded, unzipped and installed. Note: This program is free to use on small networks and will only display up to 6 IP devices discovered on your network.
    2. Once the MAC IP scanner is installed on your MAC, open the application and click the start button in the lower right hand corner of the screen.
    3. The IP scanner will begin scanning your network for IP devices. When your Zavio camera is found, you will notice that a device is found that starts with the name "Zavio-". Make note of the IP adddress assigned to the camera.
    4. Open the Safari web browser, and type in the IP address you noted above in the address / URL field and press return / enter. As the camera screen loads, you may be prompt to download a java applet. Confirm that it is OK to download.
    5. Once the screen fully loads, you should see a live view of the IP camera as well as access to all of the camera settings and controls menu on the left side of the screen.
    Please post any questions about installing Zavio IP cameras using a MAC to this forum thread.
    Posted 6 months ago #
  2. prnopt
    Mike,
    Thanks for the advice. I followed your directions and am stumped because the IP scanner found the camera as "unidentified hidden device". I typed in the IP address on safari and entered with the user name and password. I thought that at this point there would be no problem, but no feed is shown. The camera is not shown either. Additionally, bonjour shows nothing. Can you help? Thnaks
    Dan
  3. prnopt
    Mike,
    I have been fooling around with the camera, and here is where I am at. When I enter the IP address in safari I can see four boxes on the left. The language box, a settings box, a user box and camera icon box. When I click on the settings box I am brought to the web page that has in the middle "surveillance Tech.Innovator" with three arrows above it. There is no video anywhere. The lights on the camera indicate power and a connection to the network. Now what?
    Thanks
    Dan
  4. prnopt
    By the way, the camera is recognized as "Zavio" and the manufacturer shows up as well.
  5. Mike
    Support Engineer
    prnopt,
    I have a feeling that your camera does not have the latest firmware which is required for MAC and iPhone access. Can you please email me your orderid and/or first and last name the order was placed under so that I can provide you with the latest firmware?
    -Mike, mike@cctvcamerapros.net
  6. prnopt
    Sure, order id # 8813
    My name is Daniel Plaut
  7. prnopt
    I went to Zavio's site and downloaded the firmware for my camera. Stuffit cannot open the file due to ,"The file "/Users/danielplaut/Desktop/3500.F210A.03P5.bin" does not appear to be compressed or encoded. It is advised that you obtain further information about the contents of this file from the sender or provider of the file."
    This thing is driving me crazy
  8. onem
    I just bought the Zavio F312A, because it has mac support. I have 3 macs, 2 macs have 10.6 and 1 has 10.4. The old mac i can view my camera, but i got errors on the 10.6 macs because of a java problem. My macs are up-to-date ande the java site does not have any new updates for me. Is this a common problem
    sorry for my bad english
    Posted 5 months ago #
  9. onem
    i found the solution. You must run safari in 32 bits mode
    go to safari.app and get info
    change to 32 bit mode
    en start safari again
  10. Mike
    Support Engineer
    Onem,
    Thank You for posting the solution that you can get Zavio cameras working on Snow Leopard by running safari in 32 bit mode. I did not know that you could do that and it is great information for other users.
    By the way, if you are a iPhone user, CCTV Camera Pros developed a free app, the iCamViewer, that is compatible with Zavio cameras. You can see more information and download the app for free here:
    http://www.cctvcamerapros.com/CCTV-Camera-iPhone-App-s/362.htm
    Thanks again.
please bookmark or share this page for future reference
