Hello Today we had a customer call with the following question.
Question: Can you unplug the external USB HDD and plug in as needed to be used like a "hot swap hard drive".
Answer: Every time you want to remove it, you have to log into the web interface and Log into the storage settings right next to the format section there is a "Remove" button.That is the safe eject button. If you just unplug it, the most recent video files would not be properly written into the database the "Eject" button forces the database to update before removing it from the storage pool.
Posted 11 months ago #
