How can I display HD-SDI CCTV camera on HDMI monitor?
  • #31619
    A customer contacted CCTV Camera Pros today asking how to display the HD video signal from an HD-SDI CCTV camera on an HDMI monitor.
    Because HD-SDI cameras typically use BNC video output and coax cable to transmit video, you can not connect them directly to a monitor with an HDMI input. However, you can use an SDI to HDMI converter to enable this very easily.
    The below diagram shows how it works.
    #32500
    Here is another example of how to use HD CCTV cameras to display a live video feed on a HDTV / monitor. This particular customer was actually a marketing form that had a client that sold high end beach front homes and houses on the intracoastal waterway in Palm Beach and Broward county Florida.
    The builder wanted to have a live camera feed of the intracoastal view from the doc in the back of their showroom. The doc is located approximately 600 feet from where the monitor will be mounted.
    Here is a wiring diagram.
    Because the coax cable (RG59 or RG6) needed to be run more than 300 feet, an HD-SDI video repeater / extender was needed to boost the signal.
