In this forum post I will be going over the procedure to stack multiple NUUO DVR cards in a single PC.
1.) If you currently have a Nuuo DVR card installed, you will need to uninstall the current software and Drivers.
2.) Now that you are working with a clean PC. Power the PC down and put the DVR card or cards in the machine.
3.) Once the DVR cards are properly seated, if you have the 5000 series cards you will want to install the audio extension cables if you are going to need audio now.
4.) Now power the PC up once windows starts the install wizards should come up just ignore the messages. Now insert your NUUO Software disk. If you do not have this handy you can download the newest version here http://support.nuuo.com/mediawiki/index.php/New_version.
5.) Last you will need to install the NUUO Drivers. Once the drivers install you may need to reboot your system. Once the system is back up, go ahead and open the NUUO software disk and install the Server Pack.
6.) Now you have successfully installed multiple NUUO DVR cards. For more information on NUUO products you can visit here http://www.cctvcamerapros.com/NUUO-Surveillance-Systems-s/296.htm
