Security Camera & Surveillance System Support Forum » Network Support
THOMSON TG782
(3 posts)
  1. riversoft
    how to setup the port forwarding on THOMSON TG782 so a can watch my survillance sistem for my geovision GV-800
  2. JCHaldas
    Hello Riversoft,
    Here is a link to the settings that need to be applied to your Geo Vision System http://www.cctvcamerapros.com/Geovision-WebCam-Server-Setup-s/124.htm
    Below are instruction to setup your GV-800 & Thomson TG82 for remote viewing.
    1.)Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. By default the IP address should be set to 10.0.0.138.
    2.)You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
    3.)Click the Advanced link near the left of the page.
    You should now see a new menu. In this new menu, click NAPT. Click the New link near the bottom of the page.
    4.)You will need to create 3 different rules.
    Rule 1:
    Protocol: TCP
    Inside IP: Ip address of your GV system
    Inside and Outside Port: 4550
    Rule 2:
    Protocol: TCP
    Inside and Outside Port: 5550
    Rule 3:
    Protocol: TCP
    Inside and Outside Port: 80
    5.)When you're finished, click Save All near the left of the screen to save your changes.
    6.)Once you have saved the settings go to http://videos.cctvcamerapros.com/check-open-port-forwarding-tool and type in the port number that you have forwarded. Make sure it is open. If the port is closed proceed to the next step.
    7.)If you have DSL for you internet service you will need to call your provider and have them bridge the modem to your Thomson router. This is a standard process.
    Hope This Helps.
  3. riversoft
    theat is all a haw to do it works
