Wireless camera system on a firing range
This topic contains 1 reply, has 0 voices, and was last updated by  Anonymous 4 years, 9 months ago.
  • #31482
    I want to build a wireless camera system on a firing range with each camera focusing on a target. There are 10 target in total. 1 camera,1 LCD monitor for 1 target. The distance between target and camera should be around 3ft to 5ft and the distance from the target and the shooter is 30m. The camera will be slightly lower than the target and will be shielded from bullets.
    I want to know how is the setup and equipment used because I have zero knowledge about the equipment. My main concern is, can all the camera be connected to a master LCD monitor for the jury use aside from the shooters LCD monitor? Any solution will be greatly appreciated.
    #32386
    Luke,
    Sorry for the delayed response. Can you please confirm the following so that we can make a recommendation?
    1) The camera will be located 3-5 feet from the target and not 30 meters away.
    2) Is the goal to just see the targets live on a monitor? no recording?
