American Dynamics Intellex LT DVR Compatible Security Cameras
Home › Forums › CCTV Security Camera Support › American Dynamics Intellex LT DVR Compatible Security Cameras
  • American Dynamics Intellex LT DVR Compatible Security Cameras
    Here are some security cameras that are compatible with American Dynamics Intellex LT DVRs.
    American Dynamics Intellex LT DVRs are analog CCTV format. They are compatible with standard resolution analog CCTV cameras. Any of these CCTV cameras will work with a Intellex LT DVR.
    https://www.cctvcamerapros.com/CCTV-Security-Cameras-s/50.htm
    CCTV Camera Pros always recommends the following when customers are replacing analog cameras on an old DVR. Customers should consider our hybrid analog CCTV / HD security cameras. These hybrid BNC cameras work in analog CCTV mode (so they will work with your existing DVR). They also support 1080p HD modes (AHD, HD-TVI, and HD-CVI formats).
    Hybrid HD CCTV BNC Security Camera
    The video format of these cameras can easily be changed using the small joystick that is attached to the video cable.
    AHD HD-TVI HD-CVI Analog CCTV Video Selector
    Users can select the video format by holding the joystick on one of the four directions.
    If you later replace your analog DVR with an HD surveillance DVR, these security cameras will still work and you can switch them to one of the 1080p HD resolutions.
    https://www.cctvcamerapros.com/Surveillance-DVRs-s/23.htm
    You can find our hybrid CCTV /HD security cameras here. Some of the cameras on the analog CCTV camera page mentioned above are also hybrid.
    If you have any questions related to this post or anything related to video surveillance system, I can be contacted by email here.
