NUUO NVRmini – How many remote viewers supported?
Home › Forums › NUUO Surveillance Support › NUUO NVRmini – How many remote viewers supported?
  • NUUO Support,
    A customer recently contacted us and asked the following questions:
    1) How many users can be logged into the NUUO NVRmini remotely over the Internet at the same time? We already explained the limitation of bandwidth and how much would be required based on number of cameras, resolution, frame rate, etc., but is there a limitation to the # of users that can log in to the NVR?
    2) Can certain users be limnited only to being able to view certain IP cameras on the system?
    Thanks for your help as always.
    Hello Mike,
    1.)The maximum connections of live streaming: 32
    (When setting Maximum Connections in Live Streaming Server
    settings, 1 connection means that only 1 user can connect to only 1 camera. If the maximum connections value is set to 16, and each user connects to 4 cameras, the allowed connections per user will become 4, rather than 16.)
    The maximum connections of remote playback user: 8
    where to set: mini settings page->network setup->network service->live view & playback service
    (User manual page 45)
    2.)Suere,you can limit the privilege to access certain of users.
    where to set: mini settings page->management->user management->create new users
    (User manuel page 47)
