BIPRO-EC550VF CCTV Camera Dip Switch Settings
    A customer costumer contacted us with the following question: Is there a general starting place for these switches on the BIPRO-EC550VF CCTV Camera? How would they generally be set for outdoor use? I think I understand what they mean other than Back Light Compensation, Flicker Less and mirror. Please get me started, I have a lot of these to install.
    Here are the definitions and recommended default dip switch settings for this the BIPRO-EC550VF IR CCTV camera:
    1. BLC – Back Light Compensation
      Definition: Back light compensation. A function of the camera that compensates for excessive light directed at the camera causing the video to bloom or causing the images in front of the light to be unusable.
      ON (Default): Activity BLC
      OFF: No BLC
    2. ALC/ELC – Auto Light Compensation
      Definition: Photometric control, measures light intensity. Determines the iris reaction sensitivity. Sensitivity is increased when the potentiometer is turned towards PEAK, and decreased when turned towards AVERAGE
      OFF (Default): ALC / It is for Auto DC IRIS Vari-focal Lens
      ON: ELC / It is for our board lens or manual Vari-focal Lens
    3. FLK – Flicker less
      ON: 50Hz
      OFF (Default) : 60Hz
    4. AGC – Auto Gain Control
      Definition: Automatic Gain Control, an electronic circuit that amplifies the video signal when the strength of the signal falls below a given value
      ON (Default): Max
      OFF: Min
    5. Mirror – On/Off
      ON: Mirror
      OFF (Default): None
    6. Time – Hold Mode (ON: 5 sec. Off: 10 Sec)
      Definition: Delay time for LED ON/OFF
      ON (Default): LED ON/OFF after 5 Seconds
      OFF: LED ON/OFF after 10 Seconds
    7. Sensitivity – “CDS” Sensor Level Control
      ON: LED ON at 1 Lux, LED OFF at 5 Lux.
      OFF (Default): LED ON at 2 Lux, LED OFF at 4 Lux.
    8. DC IRIS Lens Level
      It is operation for IRIS manually and setting by MFG (Recommend: Don’t Changed)
    9. IR LED Level
      MAX (Default): IR LED is to bright
      MIN: IR LED is to faint
    Posted 2 years ago #
