Hi, i have got the GV-iView v2.0 perfectly working on my iphone, by wifi, or gprs connection (is slow by gprs), i have also set the settings for my 4 PTZ cams correctly configured.
When i open te PTZ menu on the Iphone, i get 4 extra tabs to use, one off them is for the PTZ PRESETS, works perfectly, by each setting the cam moves to another sposition.... the tab with the 4 arrows is for AUTO FOCUS, works also correct, but the tab with the + and - do not work to zoom in and out, when i tab these i get FORUS NEAR and FOCUS FAR....
If i tab the screen by two fingers at the same time its zooming in, and when i tab the screen with two fingers seperetly, it zooms out, is this normal???
Then my last question, if i tab the screen with one finger, i get a new menu popping up, to set he SPEED 1 to 4, this is normaly the PTZ speed for moving the PTZ cams? I set these on SPEED 4, but i can not move them manualy, when i drag one finger over the screen, i get a popup "PTZ:RIGHT", but the PTZ cam moves only 1mm, almost nothing....
can you lett me now what to do?
THX
Stefan
controlling PTZ on Iphone
(4 posts)-
Posted 1 month ago #
Hi JC, do you now this problem? do you can help me whit this problem????
Thx
StefanPosted 1 month ago # -
The zooming that you are experiencing is normal, and the speed issue is a bit frustrating as well but you might want to try using pelco P Protocol 9600 Baud rate That should help with the speed issue.
Hi JC,
Do you think this is the only problem that i almost can not move the cams in position manually??
I have now the setting of the Pelco D, i think 2400 Baud Rate.....i must check it...
Everything is working nice, fast and smooth, also with a connection with another pc over the internet, i can manually move the cam's.
Only the manual control over WIFI connection with the Iphone, if i want to move the cam manually whit swiping the finger over the screen...it moves almost nothing....
i will try to take the setting Pelco P, and try to set another baud rate.....
Thanks for the replay...
please bookmark or share this page for future reference
