Geovision 8.4 Software and Driver Update Instructions
Home > CCTV Security Camera & Video Surveillance System Forums > Geovision Surveillance Support > Geovision 8.4 Software and Driver Update Instructions
This topic contains 1 reply, has 0 voices, and was last updated by  Mike Haldas 5 years, 9 months ago.
  • #31273
    The following instructions can be used to upgrade a PC based Geovision DVR to the latest software and driver versions:
    1. First confirm with a GeoVision representative that the card is compatible with the 8.4 software. You can do so by chatting with a representative here http://usavisionsys.com or call the reseller the card was purchased through. They should be able to confirm your DVR card is compatible with the 8.4 software.
  • Uninstall the 8.2 software. You can do so by clicking Start > All Programs > GVxxx (Geovision Folder > Uninstall GeoVision Multicam System.
  • You can download the software here http://videos.cctvcamerapros.com//downloads/geovision/Geovision-8.4-Software.zip
  • Once you are done downloading the GeoVision Software extract the files. You do this by simply right clicking on the folder and you will see adoption to extract files.
  • Once the Files are extracted open the folder and locate the Driver folder. You will see a exe file named DrvInst
  • double click this icon and press the install button.
  • Once the drivers are installed locate and double click the SETUP exe icon
  • Now it will prompt you to select the DVR card series. Select the card series you need to install the software for and press next.
  • Next select video format. If you are in the US you will select "NTSC"
  • Now select the video resolution and press next. 1024 x 768 recommended.
  • If you would like the GeoVision to run on startup please check to select the Add to the Startup function
  • If you are using an IR remote control with the GeoVision Server you will need To select Install the IR Remote Control. If not proceed by pressing next.
  • Choose your destination (Default is fine)
  • Choose your program file (Default is fine)
#32248
Here is a link to a PDF file that contains the Geovision software upgrade instructions:
http://videos.cctvcamerapros.com/pdf/geovision/software-upgrade/GeoVision-8.4-Software-Upgrade-Instructions.pdf
