Port Forwarding SMC8014WN Router
  1. JCHaldas
    Please see the below instructions on how to configure Port Forwarding rules on your SMC8014WN router / gateway.
    1.) Open a web browser and type http://192.168.0.1 in the URL. [User name: cusadmin Password: password]
    2.) Click the NAT button over to the left. Now you should see the Port Forwarding option. Please click / select.
    3.)Now you will need to fill in the blanks.
    Name: This is just for your reference this can be anything.
    Type: This depends on your DVR / Camera / Equipment. Typically this is TCP
    LAN Server IP: This is going to be the device you are wanting to access remotely IP address [DVR , Cameras ETC.]
    Remote IPs: Set to Any
    Public IP Ports: Single
    Start Public Port: Port # your equipment [DVR , Cameras ETC.]
    Start Public Port: Port # your equipment [DVR , Cameras ETC.] Same as above.
    4.)Now Press the Apply button [If you have multiple ports repeat step 3 as needed]
    5.)Now lets check and make sure the port is open. Go to http://dvrport.net. [This needs to be done while onsite with the equipment]
    -Leave the IP address, dvrport.net will automatically fill this in with the correct Remote IP Address.
    -In the Enter Port To Scan section type the port # in you are trying to open.
    -Press the Scan button.
    6.) If the port is open you will use the Remote IP Address you get from the http://yougetsignal.com. However you will need to type it in as follows via web browser http://ipaddress:port number, eg. if your ip address is 74.96.36.98 than it should look like this when you type it into your web browser http://74.96.36.98:8000.
    Please us know if you have any questions.
    Posted 5 months ago #
