Speco DVR and Pelco PTZ
This topic contains 1 reply, has 0 voices, and was last updated by  Anonymous 4 years, 5 months ago.
  • #31547
    I have a Speco DVR-16TL connected to a Pelco Spectra IV SE dome camera (part no. DD4CBW18). The video is transmitted over RG59 and control uses 16-2. All the switch settings match the DVR settings. It worked for a long time with no changes. One day I noticed the camera's configure details were on the screen. I found that the camera can no longer be controlled remotely or locally and the configure screen never goes away. I tried changing the camera and backbox with no success. I have not tried changing out the DVR yet (don't have an extra). Any suggestions?
    #32433
    cwwofford,
    I apologize that CCTV Camera Pros does not carry Speco PTZs so I have limited knowledge. I do think that the configuration screen not going away on the camera is a significant clue though. Maybe Speco displays this when there is a malfunction with the camera or maybe there is a problem that is causing the menu to not go away. Either way, it almost definitely appears to be a camera problem and I recommend that you get in touch with Speco or the distributor that you purchased it from for possible warranty service.
