How do I connect a video balun to a power supply box?
Home › Forums › HD-over-Coax Security Cameras › How do I connect a video balun to a power supply box?
  • We recently had a customer call in and ask the below questions regarding our HD Video baluns that support HD-TVI, CVI and AHD cameras + they are backwards compatible with CVBS type cameras.
    Customers Questions:
    1. Which balun do I need to run video and power to my HD-TVI camera?
    2. How do I connect a video balun to my power supply box?
    Answer:
    Here is a link to the video baluns we spoke about today that will carry video and power
    https://www.cctvcamerapros.com/AHD-TVI-CVI-HD-CCTV-Video-Balun-p/vb-hd5p.htm
    Also please see the below diagram and explanation…
    This diagram how to wire VB-HD5P video baluns when a multi-camera power supply box is used instead of an individual power supply for the camera. The installer attaches a 2.1mm PT-3 power lead to the balun, then attaches the wires directly to the power supply box with its screw terminals.
    If needed here is a link to the PT-3 converter use to take the power signal from the balun and allow you to easily plug into the power supply box
    https://www.cctvcamerapros.com/Power-Cable-Lead-p/pt-3.htm
    AHD-HD-TVI-Video-Balun-Wiring-with-Power-Supply-Box
